It is currently Mon Jun 23, 2025 12:01 am
PostPosted: Thu Mar 02, 2006 1:58 pm
Anybody know a place to get these at a reasonable price?......or do they really go for around $18 a piece?
Doug
Guitars...One's too many...Twenty is not enough.
PostPosted: Thu Mar 02, 2006 2:33 pm
$18???
I just paid $23+ for a solid carbide one from LMI. Did I pay too much?
Stevesfbrown38778.9401273148
PostPosted: Thu Mar 02, 2006 2:56 pm
Nope... not too much. These little guys aren't cheap, but (if only used on clean wood) should last for years.
I have two, & use one only for rosettes.
I've been told that the HSS (?) steel ones dull in time, but are less expensive & do a better job when they are sharp.
PostPosted: Thu Mar 02, 2006 3:42 pm
http://www.ridgecarbidetool.com/html/spiral_shearface.htm
   I ordered from them before. Super expedient service. Quality parts at reasonable prices. If they don't have what you want, you can always custom order. Shipping was a killer in Canada though. (stupid brokerage fees... ).
PostPosted: Thu Mar 02, 2006 10:54 pm
Last Name: Bordeaux
City: Massena
State: New York
Zip/Postal Code: 13662
A (lengthy) search of" carbide end mills" in a search engine will result in many options and prices. I've tried several companies , but seem to average the price you quote.
good luck!
Paul Bordeaux
http://www.bordeauxinlay.com
PostPosted: Thu Mar 02, 2006 11:04 pm
First name: Craig
Last Name: Lavin
City: Sunrise
State: Fl
Zip/Postal Code: 33323
I use them as well, from Stew Mac.
The 1/32 break quick on me, so I go through them fast. I never searched for an alternative source. That price does seem right though.
Craig L.
www.handcraftinlay.com
PostPosted: Thu Mar 02, 2006 11:51 pm
alain and others in the frozen north
noted the comment on brokerage fees in the current thread on router bits.
i don't know if it will help, but going this way, i.e. can to us, if my suppliers ship through canada post i am not hit with fees, but by ups , etc. they are brutal. needless to say since i discovered this i now instruct suppliers to ship via canada post.
you might want to check if it would operate the same going from the us to can.
PostPosted: Fri Mar 03, 2006 1:13 am
Take a look here. I have used them and they work fine.
http://www.endmilldiscount.com/end-mill/micro-tool/pmt-tr-2. htm
PostPosted: Fri Mar 03, 2006 1:19 am
Thanks for the thought Michael, i'll check if it can work that way.
PostPosted: Fri Mar 03, 2006 1:37 am
Bobc, are those downcut end mills (I couldn’t tell from the site)?
I use up-cut end mills from Drill Bit City for fretboard and headstock inlay. http://www.drillbitcity.com/
I typically buy them in packs of 10 in the sizes and prices shown below.
Qty     Part No       Name    ;  Price
1     307-R10EM0360  10pc Resharpened, #64(.0360), End Mills, 3 flute     $12.95
1     314-R10EM0625   10pc Resharpened 1/16     $12.95
1     315-R10EM0938   10pc Resharpened 3/32     $12.95
I wouldn’t recommend using these for cutting rosette channels as the upcut can leave a real fuzzy edge on spruce. Downcut are better for inlay but for the price I'll take the minor inconvenience of having to clean a little fuzz.
Anthony Z38779.4031944444
PostPosted: Fri Mar 03, 2006 1:56 am
Anthony if I have this correct Right Hand cut would be down cut. Someone please correct me if I'm wrong.
PostPosted: Fri Mar 03, 2006 2:20 am
[QUOTE=Bobc] Anthony if I have this correct Right Hand cut would be down cut. Someone please correct me if I'm wrong. [/QUOTE]
Of course right hand -- duh -- me! Thanks Bob -- those are pretty darn good prices...
PostPosted: Fri Mar 03, 2006 8:27 am
Yup,
UPS Sucks into Canada. I use USPS whenever I can. It works the same as Canada Post does into the US.
PostPosted: Fri Mar 03, 2006 10:58 am
I get the double-ended carbide spiral end mills from jlindustrial. The 1/16" Hertel is SCM76062E and 1/32" is SCM76031L. The other big industrial (metalworkers) supply houses like MSC and ENCO also have them. They have "import" ones too but the name brand are under $10 so I haven't tried them. If you're in a hurry they don't charge extra for overnight in the US. I get my fret slot cutting bits (Micro100 brand) from them too.
PostPosted: Fri Mar 03, 2006 12:23 pm
   As a machinist I use upward and doward spirals all the time. To be honest I never use them in my pearl work. The chips are forced downward and if you don't have a cleared hole the chips will interfer and build heatand block the chips from clearing properly.
   Yes I know some of you swear by them and go ahead use them if you think they are great I won't change your mind . Most trouble comes from the wrong grind not the direction. A good bit will do the job well and cut clean and cooler and last longer    My 2 cents.
Dremel bits just ain't worth the trouble for inlay. Get good bits. MSC and ENCO are 2 great sources along with a few others mentioned
PostPosted: Fri Mar 03, 2006 4:34 pm
Do these MSC and Enco bits fit a Dremel?
PostPosted: Sat Mar 04, 2006 9:18 am
John, I am not sure I follow your post, what are you suggesting folks use -- up cuts or a fluted bit?
PostPosted: Sat Mar 04, 2006 1:02 pm
I use bits from MSC and Micro Grind. The are a 2 flute spiral cut designed for high speed applications. Most of these are designed for Metal and the 2 flutes will do the trick.
john hall
